brake system volume?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by seanjuan, Jun 15, 2005.
  1. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    just wondering if anyone knows how much brake fluid a 5thgen civic/3g teg holds?
    I was an idiot and listened to the guy at the parts department (Honda) when he said that I would only need one bottle of fluid... pretty sure I'm going to need more now as I'm not done bleeding yet and I'm out of fluid
    I completely drained my brakes, calipers, lines and all
    also, does anyone have any good tips on bleeding brakes... is it just a real pain in the ass when you have an empty system... seems like it's taking too much time and I'm not getting much for results?
    do you have to turn the car on ever to help build pressure in the system?
    sorry, I haven't ever worked on brakes before so I'm not to privy on all the new s##t
    thanks
    Sean
  2. pissedoffsol
    1 bottle should be enough. depends on the size of the bottle though i guess.
    its really a two person job. you can't physically hold down the pedal and release the system pressure by yourself.
    no need to turn the car on.
    pump pump pump... make sure master is topped off, bleed
    RRear
    LR
    RFront
    LF
    furtherst away from master to closest.
    when the RR starts spitting out pure fluid, no air bubbles, shes done. close it up, and go to the next one.
  3. seanjuan
    Twin Cities, MN
    I think it is just a pint bottle.... but it has to fill the pistons as well as the lines because I totally drained them
    I have been using a vacuum kit that I bought but also had someone helping me out as well...
    thanks though
  4. abdelsol
    abdelsol Member
    Why did you drain the system?
    Master cylinder too?
    Pint will not be enough get a quart. If the system set open by more and flush it..... Fluid it cheap...... not stopping priceless....
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I used over a quart when I did mine, no wya a pint is going to be enough if you emptied them.
  6. phunky.buddha
    Dallas / Fort Worth, TX
    The last time I did a full system flush, it only took me a pint- and that was with the larger 15/16 master cylinder too.
  7. pissedoffsol
    werd, i've never used more than that...
    and i have the larger GSR master resivoir on my car now.
  8. xj0hnx
    C.C.TX.
    Likw whoa, I had more than a pint in the bled bottle.
  9. pissedoffsol
    if you're bleeding more than a pint, you're doing something wrong. a quick "Pssspft" and re-tighten is all you need. you don't have to sit there and let it drip out. a table spoon to about 1/4 cup per corner of spent bled fluid is about average i'd say.
  10. xj0hnx
    C.C.TX.
    Everytime I have bled brakes after draining or nearly draining the system, it takes more than a couple quick hits at each corner.
  11. pissedoffsol
    sure- the first corner takes a while... but theres no need to let perfectly good fluid out. you're trying to get rid of the air in the lines-- not the fluid in the lines.
  12. seanjuan
    Twin Cities, MN
    yeah, I think I have been letting too much fluid out... especially at the first corner
    I drained the whole system because
    A. it was original old fluid
    B. I replaced all the calipers/drums with the brakes from a 98 gsr
    c. I put on a 7/8 MC
    d. I replaced the hardline going to the front right
    anyway, a buddy of mine that works at honda gave me another pint for free so that should be enough to finish even if I over do it a little
    I kind of was doing it to flush the old dirty stuff out of the lines and calipers as well
  13. xj0hnx
    C.C.TX.
    Actually, it's R Rear, F left, R left, F right :)
  14. seanjuan
    Twin Cities, MN
    yep, that is what Helms says
  15. pissedoffsol
    odd... my del sol one says the way i have.
    technically, you're supposed to start from the furthest path and work your way to the shortest path.
    i dunno.
  16. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Thats what I heard too. Damn these conflicting methods right before i'm doin a brake swap.
    When you said you drained the whole system, did you let the MC go empty? If so, is that bad? I heard not to let the MC go empty when you bleed brakes because something about damaging the seals in the mc. Is that true because at the sametime, how else are you suppose to completely flush the old fluid if you wanted to do so unless you just kept pouring more and more fluid and bleeding the crap out of it.
  17. GSRCRXsi
    MD
    i just follow what the helms says, and its always worked for me
  18. xj0hnx
    C.C.TX.
    What year DelSol Helms do you have? I got that from the 95 DelSol and the 94 Civic.
  19. pissedoffsol
    actually, my helms is for a 94 integra
  20. seanjuan
    Twin Cities, MN
    brakes are bled and the car stops when the pedal goes down
    pedal isn't very stiff but it feels ok
    I might rebleed a little to see if there are any tiny little spare bubbles hanging on in there
    only thing is that the hawk pads I put on the back came with a backing plate on them that doesn't work with the caliper.... the caliper only contacts about half of the backing plate... and therefore the pad is only using the outside half of the rotor
    I'm thinking that I will pull the pad out and remove the hawk backing plate and put the honda one on from the old pads
