Brake upgrade
Discussion in 'Wheels / Suspension / Tires / Brakes' started by civicsi1215, Jan 24, 2011.
  1. civicsi1215
    civicsi1215 New Member
    Hello all,
    Im new to this forum...i need help and advice on a upgrade on my 93 civic si hb. I have the all four disc brakes my pump or master cylinder is giving up on me....what pump or master cylinder should i upgrade to??:huh:
  2. TurboMirage
    just replace it :shrug:
    or is the GSR MC bigger?
  3. E_SolSi
    the one for the 91 EX sedan bolts right up to your booster and is 15/16ths (as opposed to your 13/16ths one now)
    if your booster is going out as well you may want to upgrade to a non-ABS integra booster and MC... you will also get the 15/16ths MC but you also get the higher volume booster... this requires some modification to the lines
  4. civicsi1215
    So i should get the 91 EX booster and MC?? will i have to modify the lines on this one?
  5. E_SolSi
    you can use your stock booster with the 91 EX MC
    everything i have read says that you do not need to modify the lines for this MC
    i have not done this (for mine i went with an ITR 1" MC and booster and adjusted the lines as needed )
    if your booster is shot you can replace it with a stock one for your 93 Si and put on the 91 EX MC (you might be able to use the 91 EX booster... i dont know that they are any different)... or you can go with the integra booster and MC
  6. civicsi1215
    K tks for the help im going with the 91 EX MC with my stock booster...
  7. civicsi1215
    Got it done! works great...thanks again.:D
  8. E_SolSi
