honda brakes are good but if you dont take care of them, calipers can seize up. If your alright with cars, take off wheels, unblot the calipers (you dont have to completely remove them, and you dont have to remove them from the line, just so that you can inspect them.) Check to see were the dust boost are, if that little guide, can move freely (should be a little tight, but it should be easy enough that you dont need to use tons of force.) When you are ready to put everything back together, clean off the bolts bolts with a steel brush then put antiseize on them.
