Anyone out there ever put rear disc onto a 91 accord EX 4 door.What do I need off of a 92 to swap them over?Spindles?Brakelines?MasterCylinder?obviously calipers, rotors,brackets,etc.How hard of a conversion is it I consider myself a competenet shade tree mechanic just need the info.I have heard that in some cases where a master cylinder is necessary you can simply use a proportioning valve to the rear while using the drum mas. cylinder?True/False.any info. would be appreciated as usual.
