Brakes
Discussion in 'Civic and CRX - EF' started by jowilson275, Mar 2, 2010.
  1. jowilson275
    jowilson275 91' Si B16A
    okay i have 90-93 integra hubs, spindles, and calipers on my 91 crx. now when purchasing sexy new rotors, do i need to buy them for da of ef?
  2. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    Buy them for the car they came off of (da).
  3. jowilson275
    thats what i figured. just wasn't sure if there was any real size difference
  4. wikedeye
    Savannah, Ga.
    There may be, but you want the ones that will fit with the integra parts because thats what they are from.
  5. jowilson275
    ok cool. getting some drilled and slotted rotors...
  6. GlassHeadlights
    Calgary, AB
    I hear brembo blanks are better...but I still don't know what they are. Lol
  7. Magana559
    Magana559 The Warden
    fresno Ca
    brembo stock replacment.
  8. jowilson275
    yeah i just saw those. the look similar to stock. my only guess is that they have a littly more surface area
  9. efhondakid
    Akron-Canton, Ohio
    Drilled and slotted rotors are made for race apps, the slots/holes actually shave the pad to prevent glazing under extreme conditions, so in normal everyday driving situations your just wearing out pads faster. Like said before, a set of Brembo blanks and a good set of pads will be plenty.
  10. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
  11. Matts96HB
    Matts96HB . Moderator VIP
    yeah i have drilled/slotted fronts on my hatch. they eat pads like crazy. :thumbsdown:
  12. blklgt
    blklgt New Member
    elkton, maryland
    bump for brembos
  13. jowilson275
    got it. blanks it will be then. or at least something that is vented...
  14. jamesA
    I love my brembo blanks. They've lasted two years with Hawk Pads, you don't need fancy race stuff unless you're strapping a rocket to the back of your car.
  15. eg6sir
    1 person likes this.
  16. jowilson275
  17. 99sidude
    Ohio
    That's the exact setup I have. Wasn't too expensive to pull together and the braking is amazing. Make sure you have a 40/40 proportioning valve and a larger master cylinder. For me, that made the pedal go from being soft with lots of travel to a brick wall that has awesome feel to it.
  18. jowilson275
    what master cylinder would i need? the one i have on there now is from a 91 civic ex
  19. GlassHeadlights
    Calgary, AB
    Thats a good upgrade but the 90-93 Integra NON ABS booser and and master is a excellent upgrade aswell as the 4040 prop valve off the same car. I have that on my rex and it was night and day, thats with OEM pads and rotors too.
  20. jowilson275
