Brakes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by vtecsir1, Mar 5, 2003.
  1. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    do i need to change my front hubs to mount integra rotors and calipers on them? or can i just pick some calipers and rotors up and swap them right on? i have a 95 cx civic, trying to get a little more braking out of it. thanks
  2. H0ndap0w3r
    H0ndap0w3r Banned
    my opion would be to just swap out everything, the whole gsr/ teg suspension. the control arms and everything. fix the rubber bushings, since there most likely cracked and broken.
    so do the rear disk and front disk. a whole gsr suspension should cost u about 350, then about a couple of hours of install and ur done.
    i put 98 ex rear disk on my ef. ( i think they were 98 ex, not sure)
