build parts wtb
Discussion in 'Parts: For Sale/Trade/Wanted' started by INJEN78, Apr 19, 2008.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    looking for DSM 450cc injectors(blue tops)
    LS throttle cable
    LS Dizzy--prefer obd0,but if the price is right i can do obd1
    B-series clutch cable bracket
    90-93 Rear engine bracket
    89-91 EF passengers upper control arm(with good balljoint) i broke mine
    need this stuff to complete my build,lemme know prices shipped to 06415
  2. BrokenRex
    BrokenRex New Member
    hey injen, just fyi, on ebay there's a honda dealer that sells LS throttle cables for $25, brand new. the bracket you need can be bought from a dealer for $5-$9. not all bseries brackets will work. i ordered one for a 93gsr and it was wrong, then i had them pull the only one they had in stock (for a 94crv if i recall correctly) that worked out fine. but then i have an aftermarket manifold, check the bolt pattern, one has two holes close together, the other they are farther apart, then others still have two that are far apart and kind of stepped (one higher than the other.)
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    im talking about the bracket that holds the back of the motor to the mount,,i dont run the bracket that supports the intake manifold,,they are a waste of time ,effort,and money:D
    but thanx for the info,,i was just seeing if someone here had them cheaper
  4. BrokenRex
    ooooh, the mistake i made was hastily reading your "b series clutch cable bracket." because i needed the throttle cable bracket i must have dyslexicly assumed you needed one too, forgive me.
  5. itrsleeper
    itrsleeper New Member
    i gotta obd2 pr4 dizzy. not sure if it works. make an offer
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    nah sry bro,,need obd0
  7. sevenhillsbilly
    sevenhillsbilly New Member
    do you still want that spray?
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
  9. sevenhillsbilly
