Build question
Discussion in 'Engine Building' started by Boost Addiction, Jan 23, 2009.
  1. Boost Addiction
    Boost Addiction New Member
    cincinnati
    Well the guys at G2IC.com didnt see a problem with this setup but I thought Id run it by more than one group.
    B18a block
    GSR rods and crank
    LS pistons
    B20 head (cammed but havent decided which ones).
    Goal is 300whp, I figured with that bottom end I could spin a little higher and with the LS pistons I would be in a safer compression range.
    Any input is welcome.
