i am starting to plan a b18 motor build-up that i will be putting into my 96 civic hatchback. i would like to use all forged rods, pistons, crank, valves and upgraded cams. i was also thinkin about doin a street/strip port and polish. i would like to build this motor so after running it all motor for awhile i can put a turbo on it and the engine will be able to handle it(will i need to lower the compression?)
what do u suggest i do, what kind of block should i get an OEM or a Dart block
also who makes all the best rods, pistons, springs, cams, i was thinkin about doin all Skunk2
Give me your input and i will deffiniatly take it into consideration while planning my build.
