ok,im going for a turbo setup..ls turbo...but right now im about to build the head...heres what i want to do,but i got a issue i need some input on :
1.Remachine/resurface
2.Crower stage 1 cams,retainers,springs,valves, and cam gears
3. PNP
4. 3 angle valve job
now i know that the cams are not "turbo profile"...but i want to rev a little bit higher (7200) and gain a little bit more NA power on the stock compression...will i run into any problems going with a stage 1 cam on a turbo setup?...my setup goal is about 275 to 300 whp...(yes i am gonna build the block too)....any input or warnings?
3. PNP
