built b16 turbo ready
b16crxsi
team ugly
selling my b16 turbo project. engine is new, never installed or run. bottom end complete, head not assembled.
block- .020 over, arp main studs, arp head studs, new oilpump, new clevite bearings.
rods-eagle h beam
crank- oem standard size
pistons-wiseco 9.2:1 flat tops.
head-port matched and cleaned/ beadblasted
stock cams, springs and valves.
vision cam gears
gasket set
need to sell due to layoff.
also have a s1 trans with a honda oem lsd installed and brandnew gripforce clutch.
everything, 2500 obo.
located in ontario canada but could ship from michigan at buyer expense.
2500 shipped obo. will part out.
bottom end 1600
head complete un assembled 500
trans, with lsd and new clutch 500
make offers. will be shipping from 48060
do you have any more pics of the trans. how many miles on it and ever had any problems with?
not sure exacally the miles, i myself put about 3000 on it and never had any problems. no grinds or bearing noise. clean up the outside and put in new oil.
i installed new driveshaft seals. i also have a midshaft ill throw in
