ok guys, i need help building a complete ls/vtec, which parts would you go with.... i need help with the following.....keep in mind this motor will be turboed later NOT N/A.......
which...
pistons
rods
cams
cam gears
retainers
valve springs
sleeves
injectors
throttle body
fuel rail
tranny
i think thats it......any suggestions or setups would be great, keep in mind, i cant afford the best of everything, and this is also for a drag car.....
which...
pistons
rods
cams
cam gears
retainers
valve springs
sleeves
injectors
throttle body
fuel rail
tranny
