Bunch Of Chipped Vtec P28 Spec Ecu's
Discussion in 'Parts: For Sale/Trade/Wanted' started by JDM-JAMES, Nov 22, 2008.
  1. JDM-JAMES
    JDM-JAMES New Member
    hey i got 4 ecus freshly chipped just came out of the oven :p There all tested to work in my personal car with a custom map everything works like it should these are guaranteed to be working and the soldering job is A++
    i can make you a custom map for b series h series and d series motors n/a turbo for no extra charge it will come with the ecu ready to plug and play.
    these are ready for hondata ectune crome neptune uberdata
    they are chipped and vtec converted and the p09 and p05 ecus are converted to run a 4 wire o2 there all basically p28's now for a low price
    The sockets are Gold plated Aries
    PRICES:::::
    p05 p06 p09 120 shipped priority mail 2-3 days with tracking with new sst 27sf512 eprom with a custom map loaded to your spec
    p30 160 shipped priority mail 2-3 days with Tracking currently has a map tuned for a b16a ITR Cams T3/t4 60 trim and 450cc injectors stock map. i can load a custom map to your specs on this ecu if preferred.
    THANKS :3dbiggrin:
    If you have any questions call me 619-813-5149 this is my cell and my name is james.
  2. JDM-JAMES
    bump
  3. younggun
    younggun New Member
    I will trade you my chipped p28 ECU for the p30 and I can throw some other parts on top let me know if your interested.
  4. JDM-JAMES
    Thanks for the offer but im only looking for stock obd1 ecus and sohc performance parts and paypal money bought a few things on ebay :D
  5. GavinDelSol
    GavinDelSol New Member
    this may seem stupid question but i have been told that my P28 ecu will run My B18C4 engine. the way this works is if i bridge to different components within the ecu, now which components i bridge is a different story.
    is this possible?
    i also have a standard obd1 ecu , standard obd2a (P9K) ecu & P28 ecu
    thanks Gavin
  6. JDM-JAMES
    the p28 will run you motor but not to its full potential i dont know much about the b18c4 but if its like the usdm b18c1 the p28 will not control the iab's and the p28 does not have knock sensor support and of course not the correct timing and fuel maps.
  7. JDM-JAMES
  8. GavinDelSol
    could one of your ecus run my engine to full power? B18C4
  9. JDM-JAMES
  10. younggun
    younggun New Member
    I have a virgin one too
  11. JDM-JAMES
    which ecu i can work out a partial trade
  12. younggun
    younggun New Member
    I have a virgin p28 and p08 ECU
  13. JDM-JAMES
    i will trade both + 40 for the p30
  14. younggun
    younggun New Member
    well I just sold the p28 so I only have the p08 ECU now
  15. JDM-JAMES
    pmed
  16. JDM-JAMES
  17. stevennn09
    stevennn09 Member
    Ohio
    need a ecu for a 96 up teggy motor. do u have one?
  18. JDM-JAMES
    sorry i only got obd1 ecus
