burn1 d16z6
Discussion in 'ECU's, Electronics, and Tuning' started by stedscivic, Jun 10, 2005.
  1. stedscivic
    stedscivic Senior Member
    got my burn1 from moates today and my buddy wants me to burn him a chip
    we just want to change the vtec engage and no speed limiter
    for the speed limiter all we do is check the box i know that much
    what about the vtec engage just put what we want to put as the vtec engauge at?
    we dont have to mess with the boost tabs or any other tabs do we?
    its for a d16z6 intake and exhaust is all thats done NO BOOST just stock motor and we want to see if the burner works all we want to do is no speed limiter and vtec engage
    if someone knows a better tune than that of the stock please feel free to share
    first time using uberdata and want to make sure we can get it to work
  2. stedscivic
    anyone out there use uberdata that can help a newbie to uber out?
    id go on uberdata.pgmfi.org and post but it wont let me register whats up with that?
  3. pissedoffsol
    load the stock p28 bin file.
    make changes
    burn chip.
    insert chip into ecu.
    drive around and test it out
    its all point and click
  4. spydy43
    spydy43 Senior Member
    :werd: You dont have to mess with any of the other tabs if you are only changing the speed limiter and vtec points.
  5. stedscivic
    he wants to set his vtec as low as he can
    i told him if he goes to low it cant be good on the motor
    can i give him a second opinion from someone on here cause he wont listen to me
  6. pissedoffsol
    you can set it where ever you want... the car will just be a HELL of a lot SLOWER.
  7. CoreyR
    CoreyR Senior Member
    the lift on the cams high lobe is too big for the engine at a low RPM. just let him try it and he will realize when the car is slow as shit that its not a good idea.
    let him set it low and when hes not looking change the rev limiter to something like 4500 so he think he fucked something up from setting it so low.
  8. stedscivic
    that last part sounds like a good idea
  9. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    lol, that is funny shite... "roger, roger, we got a ricer here!, 10-4 buddy!" your friend should be glad he has a buddy looking out for him, doing his research for him. Wish there were more people like you out there, keeping the vtec-poppin peeps at bay :)
  10. stedscivic
    ok i tried burning a stock p28 and just removing the speed limiter and changing the vtec engagment to 4700 and we get a cel
    once i save it in chrome or uber they seem to change after i save and dont work in the car what could be the problem
  11. pissedoffsol
    perhaps you're not burning it right? did you pull the code?
  12. pissedoffsol
    from the crome faq...
    Q. I get a solid CEL when I edit a stock ROM with Crome. What things should I check?
    A. Did you:
    -Remove the checksum routine from the ROM?
    -Disable any hardware features not present on your ECU (knock, PA, injector test circuit, etc.)
    also, uberdata .bin's are NOT directly compatible with crome bins. so be careful what you made it with, and what you viewing it with.
    if you burn with uberdata, but want it in crome, you will have to import FROM the CHIP into the other software
