Burned Ecu
methos713
Member
okay, i burned my chipped p28 ecu. After that my obd1 distributor didn't work...now i'm using a gsr distributor and was wondering if a ecu got burned, would it affect the distributor...cause we forgot to take out the knock sensor wire that was need for my other ecu...a jdm p30. I'm planning on putting on the p28 again...just to see what happens, but i'm kinda scared it will mess up my p30 ecu....by the way my p28 was chipped w/ vtec@4700 and revlimit@10k rpm.
Between your motor,your wiring, and you dipstick, you need to take your car to a pro, and have it fixed.
