you probably have to keep adding oil because your piston rings are fryed like chicken. if you plan on keeping the motor you should rip the head off and change them. oh, i also have a dx motor in storage that was not burning oil when i last drove it. if you want to save yourself some coin and some time you could buy my bottom end for next to nothing and have your problem fixed. also if your interested the head on that motor was just sent out to be milled and pressure tested so the compression is up a little and it has a new head gasket, intake gasket, and exhaust gasket. i put 6000 km,s on the motor before i did my own frankenstein swap, so shes still fresh...
