burning oil
Discussion in 'HYBRID -> ED-EF / DA' started by vpower, May 11, 2011.
  1. vpower
    vpower New Member
    L.A.
    I have an issue with my 91 si burning oil...its swapped with a b18c and I'm burning abt a quart of oil roughly every 700 to 800 miles...also I'm not heavy on the pedal but I do accelerate sometimes( not being sarcastic) any help would b appreciated...
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    haha does it smoke ? 99% like every other abused honda engine, bad rings.... orrrrr heavy vtec'ing
  3. 99sidude
    Ohio
    My guess is rings. Compression test it before you do anything.
  4. dilbeckskate
    Kennesaw Ga
    yea not saying this guy did, but i love to see guys rev their hondas 9-9.5k and wonder y it smokes on the daily
  5. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    probably why my b16 was so bad on oil, 3qts every 1k miles.
  6. vpower
    vpower New Member
    L.A.
    When I purchased the car it had already had the swap done and burns same amount of oil...and I don't rev to 9-9.5 lol...I see idiots doing it tho and I just lmao...so u believe its rings???and whays will a compression test fully tell me???
  7. dilbeckskate
    Kennesaw Ga
    compression test will tell you yes, Id honestly if you have another DD id take it as an opportunity to break the engine down and replace everything, rings, seals, gaskets, etc, thats just me, or just put whatever nasty oil honey you can in it to get it to stop smoking and sell it to some kid
  8. vpower
    vpower New Member
    L.A.
    What's a rough estimate of rings gasket seals etc. What will it cost roughly???
  9. D16SiHatch
    D16SiHatch New Member
    It could vary greatly. Depends on if you're doing the work yourself, and i assume you are not, otherwise you would probably of just added up the price of parts on your own. So since the motor has to be competely tore down and rebuilt basically, we're talking some serious cheddar.
  10. dilbeckskate
    Kennesaw Ga
    orrrr grow a pair of balls and call up some buddies and do it yourself
  11. B16
    B16 Super Moderator VIP
    yay area, CA
    Does it smoke at all? During startup? or while accelerating?
