erebunicrx
my name is Dale
im selling anything to do with hondas that i have so here is the biggest thing i have..
Golden Eagle Sleeved 84mm 2ltr ls block
built by a local reputible shop
all new acl bearings
84mm cp pistons 9:1 compression
eagle h beam rods
aebs main studs
typer r water pump
micropolished crank and all is balanced. all it needs is a oil pump
also have a complete golden eagle ls vtec conversion with 84 mm headgasket and head studs.
last is a stock b16 head with valve cover, vtec solinoid hondata im gasket
aksing $2700 for the block, 4 for the head and 300 for the lsvtec stuff, or buy everything for 3k
eagle h beam rods
aebs main studs
typer r water pump
