Byrons boost project.
Discussion in 'Auto Multi-Media' started by efhondakid, Apr 12, 2010.
  1. efhondakid
    Akron-Canton, Ohio
    Been slowly gathering part to boost the old EF for a about a year now and almost have everything needed. So since it was nice out today I decided a little mock-up session was in order.
    Just to give you an idea what Im workin with.;)
    Intercooler fits damn well, very minimal cutting to the bumper cover, but as you can see it sits way too low. A little notching of the bumper support is in order so no big deal in that department.
    Plenty of clearance here, but
    This is where I ran into a head-scratcher, I figured since Ive already hacked the shit out of my crossmember to fit the EG rad I think a traction bar is in order and if that still doesnt give me the needed clearance I my have to do a pie cut 90* welded to the outlet.
    More progress to come so stay tuned.
    1 person likes this.
  2. invisibledemon
    Tn
    ok, am i wrong in seeing that your radiator support looks completely screwed up?
  3. TurboMirage
  4. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    It's an EF, mine does it too.
  5. invisibledemon
    Tn
    I have had my fair share of ef's and I don't remember any of them looking that bad.
  6. TurboDave
    TurboDave New Member
    Eastern, CT
    Clock the turbo...
  7. efhondakid
    Akron-Canton, Ohio
    I cant, Im stuffing 10lbs of shit into a 5 lb bucket here. The outlet is already parallel with the radiator, after looking at it some more a plain old 90* coupler should work.
    Got the intercooler mounted in the final postion today, had to end up cutting the grill out after the bumper support was notched to move the IC up. :( The IC will be getting the flat black treatment to keep it as stealth as possible. Just need to get to Summit so I can snag some couplers then I can plumb it all in.
    Prepped for notch.
    Fits pretty good after cutting it out, just need to get some metal to cap off the cut out to give back a little bit of the strength that was taken away.
    Just need some black paint. :D
  8. 92stoccord
    Salem, Ohio
    What's the verdict on your core support?
  9. efhondakid
    Akron-Canton, Ohio
  10. 92stoccord
    Salem, Ohio
    Well shit, then mines not any better lol.
  11. efhondakid
    Akron-Canton, Ohio
    Not really worried about it, everything lines up decent so no big deal.
  12. SlushboxTeggy
    NJ to MA to CA
    Love the mounting locations of the IC. Creative thinking.
  13. newb
    newb phresh VIP
    Backwoods Northwest
    I think Ill watch. :popcorn:
  14. invisibledemon
    Tn
    hey, as long as it holds the radiator and keeps the hood down, all is good.
    should be a good build.
  15. Matts96HB
    Matts96HB . Moderator VIP
    watching this for sure. looks to be a solid build.
    good luck, byron. :thumbsup:
  16. GlassHeadlights
    Calgary, AB
    Nice thread.
    Is anything going to be done internally to the motor?
  17. efhondakid
    Akron-Canton, Ohio
    Keeping it all stock for now, Ill be happy if I make 200, I dont want to lose drivability/reliability, just wanna put a little bounce in her step.;) If it makes it through the summer then the motor is coming out and an getting freshened up and the boost will be turned up.
  18. GlassHeadlights
    Calgary, AB
  19. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    nice.... the ic looks good.
    200whp or better will be quick in that light little car.
  20. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
