Cable To Hydro
Discussion in 'General Tech and Maintenance' started by hooktupciv95, May 5, 2003.
  1. hooktupciv95
    hooktupciv95 Member
    does anyone on here know if there is a kit out there to convert a cable tranny to hydro? if not, its not possible to just bolt up a 95 ls tranny(hydro) up to a 1990 ls motor? the 90 ls motor has a cable tranny?
    thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Last time I checked HA Sport had a kit in development, give them a call and see if it is finished.
  3. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    i think that a 90 ls motor was a dseries and the 95 is a b series if that is the case then no you can not bolt up the tranny you might be able to find one that is from another d series if that is the case
  4. lsvtec
    No, the 90 Integra had a B18A1.
    You will need to get the clutch and flywheel from a 92+ B series to make that tranny work.
  5. hooktupciv95
    hooktupciv95 Member
    sorry im not to smart with this stuff, so LSVTEC, what tranny are you talking about? are you saying it WILL bolt up, as long as i get a clutch and flywheel for a 92- up?
    what was the name? its HA Sport, not Has Port?
    thanks man, you are saving me :worthy:
  6. lsvtec
    Yes, the tranny will bolt up if you get a clutch/pressure plate/flywheel from a 92+ B series.
    www.hasport.com but they do not update their site all that often. Give them a call.
  7. hooktupciv95
    hooktupciv95 Member
  8. lsvtec
    If this is going into a car that already has a hydro tranny, you won't need the HA Sport kit.
  9. hooktupciv95
    hooktupciv95 Member
    yes it is(95 civic dx). thanks for clearing that up :D
  10. i got a 99 si tranny short gear ratio for sale if your interested...should bolt into the b18 just fine
