khai_tuan_nguyen
I just bought one and installed it. I am a mechanical engineer, so I like to figure things out, but couldn't exactly figure out how this works from the directions. It has a foam filter on the outside, then a different foam filter on the insider separate by some rubber tabs and this plastic spring thing. Supposedly when the intake retains water the bypass spring does something, don;t know what or how and it absorbs the water and makes it go out of the bypass valve. How does it work, and why does it say to push on the tabs after i install?
Let me know what you guys know.
Thanks
Khai
Thanks
Khai
