i heard that a 99-00 civic si cold air intake will fit onto a b16a1 with a little modification, is this at all true? if not then is there anything that will fit as far as CAI's go?
just buy two really cheap short ram intakes and make a custom semi cold air, you won't be sucking in hot engine air and nor will you been sucking up water when you go through a puddle or drive in the rain. . .
