California Bodykit
Discussion in 'Body / Exterior / Interior / Cosmetics' started by kelbizzle, Dec 20, 2005.
  1. kelbizzle
    kelbizzle Junior Member
    I was wondering what kind of modifications you would need to make for this to work and look GOOD. Also anyone ever seen it with TL headl lights or are they the same thing. They look different. I still might go for the JDM conversion for my teggy. But money is the issue.
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    you will spend more time and money getting a cheap crap kit to fit than just buying and painting OEM JDM body panels.
    A friend of mine did an S15 conversion on an S14 (got the kit from extreme dimensions) and it took A LOT of work to make it look nice.
  3. driver1
    driver1 Senior Member
    if money is an issue, take it from me u dont even want to try. U will ruj out of money by the time the bodyshop is 1/3 done and end up pulling your car out looking worse than it did when it went in
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    not sure if the TL headlights are the same but i'm guessng they are not since the company specifically states that they use CL headlights...
    and you don't want to try this kit
    its fiberglass, it will break
    you need to fab headlight brackets which will more than likely not allow you to adjust your headlights
    and the kit fitment from the manufacturer is shady at best...
  5. kelbizzle
    Thanks guys I think I'm gonna go with your advice. I'm going to get the jdm conversion.
    If I had the loot I would get the other one. One good thing about the jdm is replaces a messed up spot in my fender from my wheel falling off.
    Hey anyone even seen those M3 or Z3 sport with the crhome oval thing? Do you know where I could get em.
  6. Battle Pope
    The JDM conversion should come with fenders - just use the ones it comes with. I doubt you'll be able to find aftermarket fenders for a JDM type R anyway.
  7. E_SolSi
    if you are really that dead set on gayifying your car just get a bunch of these and put them all over it
    [​IMG] [​IMG] [​IMG]
    same effect and a lot less expensive
  8. PhyRe
    PhyRe Senior Member
    ct
