Well piston area is not necessarily the definition of "better braking". Yes, there is larger pad to rotor contact area, so yes, the brake system could generate more baraking torque. Also, you have to take into consideration master cylinder size in relation to caliper piston size, since a caliper with more piston sorface area will affect pedal travel.
