call me on my new cel
Discussion in 'HYBRID -> EG-EK / DC' started by PhyRe, Feb 16, 2005.
  1. PhyRe
    PhyRe Senior Member
    ct
    todays magic number is 24. thats the new code of the day. any one know what it is? it used to be a 23 the knock sensor but today it blinked a 4th time(along with the 43 i still cant fix)
    setup is 93 dx with obd 2 gsr :wtf2:
  2. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    what ecu are you using? if i was you i would be using a chipped p28 we hooked mine up to my boys obd1 gsr and wow what a difference throttle response and everything and he cel went away too ;)
  3. PhyRe
    PhyRe Senior Member
    ct
    the ecu is an obd1 p72 chipped with a jet chip.
  4. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Ok obd2 /= obd1. You might want to give us somemore details, cuz I can tell you right now that if you plug an obd1 ecu straight into an obd2 you are going to have issues
  5. PhyRe
    PhyRe Senior Member
    ct
    issues how? when i first started the swap back in sept everyone said use an obd1 ecu? why would every one not know about the issues with it? what details do u need? everything is stock exept the ecu and an iceman short ram. preformance wise thats it. i should prob check it with stock ecu. anyone wanna sell and obd1 p72 CHEAP?
  6. hybrid89
    hybrid89 thistownsucks...
    SoCal
    OBD conversion harness?
  7. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    his car is obd1, he would not need a conversion harness to run an obd1 ecu it will plug right in
  8. hybrid89
    SoCal
    I agree, but the obd 2 motor has sensors like the crank angle sensor that od1 motor does not. I know the ECU shouldn't read it, but it make sno sense why his errors and changing, unless it is a bad ECU
  9. PhyRe
    PhyRe Senior Member
    ct
    see thats what im starting to think now. because since the swap i had a 23 ks all day but it started coming on sooner and then i checked it and its a 24 and one prob can fix its self so its gotta b the ecu. anyone in the ct area with one i can borrow? all my boys around here have obd2 p72 it sucks.
