Cam adjustment question
xj0hnx
I wanna be sedated
VIP
Ok, advancing your cam gear brings the valves closer to the pistons, because you're setting them to open later right? My question is, is it possible on a B16A with CTR cams and OEM head gasket to advance them so far that they contact the pistons? Just wondering since I will be playing with this soon, and I don't want to smack the insides around.
you'll be fine, just don't be advancing like 10 degrees.
chances are you'll end up adjusting them max by 3 degrees.
Cool, these go + or - 10 degrees, but yea, I have only seen anyone going more than +3 a couple times.
yeah, 3 or 4 is like the max you'd ever want to go make power.
but with a high dome piston and poor cam settings, its VERY possible to tap a valve. thats why you clay it :)
