Cam break in??
Discussion in 'Engine Building' started by Magana559, Feb 26, 2009.
  1. Magana559
    Magana559 The Warden
    fresno Ca
    Alright guys, This may be a N00B question but I really need to make sure I have my info correct.
    Do you or do you not have to do a break in procedure?
    I know in old pushrod motors you have to Idle above 2k RPM for 20 min....but what about in hondas?
    oh yeah I forgot, they are a used pair of BC stage 3 cams in a GSR head.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    make sure that you use a good moly based assembly lube on the cam lobes
  3. Magana559
    fresno Ca
    Cool I already did that but do I Idle for 20 min above 2k rpm?
  4. Magana559
    fresno Ca
    Bump!
    Gonna finish building and swaping today! Still need to know how to break them in.
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Why would you break-in 'used' cams? You don't have to break them in. Just make sure they are lubed so they aren't dry when you start the car and let them rip...
  6. Briansol
    no break in required. just re-check your torque figures after a 15 in drive to make sure nothing worked out
  7. Magana559
    fresno Ca
    Thanks a bunch guys! Gonna let em rip tomorrow! Finally gonna get the engine in the car!
  8. 97hatch
    97hatch ?
    Anderson IN
    i prefer rotellaT oil for break in on fresh engines and cams but your cams are used and no point in breaking them in. Rotell T has extra adatives in it that will help with a fresh build i think compcams actall recomends it also
