Cam durations, I need opening/closing specs
Discussion in 'Engine Building' started by xj0hnx, Apr 11, 2004.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Ok, so in order to truely find out how much I can adjust my cam gear before contacting the piston, I need to know the centerline degree.
    Does anyone know the opening BTDC and closing ABDC degrees of a Civic Type R cam shaft intake and exhaust?
    I have the formula to get it, but I need the numbers.
  2. xj0hnx
    C.C.TX.
    I know one of you knows this.
  3. phunky.buddha
    Dallas / Fort Worth, TX
  4. pissedoffsol
  5. phunky.buddha
  6. 97CTR
    97CTR Senior Member
    does this help?? or not what you are looking for.
    Int-278 dur. / 11.5mm lift
    Exh-280 dur. / 10.5mm lift
    or you could just clay the motor!!!!! :D
  7. xj0hnx
    C.C.TX.
    Thanks for trying, I have those. I need the degree on the 360 at which the cam first contacts the valve, then the degree at which it loses contact. I don't want to take my motor apart, to clay it for only what is preobably going to end up being a 3 degree adjustment:p
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    is this a stock b16a with ctr cams and nothing has been decked or milled? if so, you're safe with any adjustments you'll be making. i went +3 degrees on my intake side with no problems. ctr's don't need much changing as far as cam timing goes, at least not enough to worry about piston/valve contact.
  9. xj0hnx
    C.C.TX.
    Yea, I know, but I want to be sure. I know they won't contact, but I am trying to learn something at the same time, so hey :)
