Cam gear key broke with cam shaft
Discussion in 'Civic and del Sol - EG and EK' started by smoothekang, Feb 22, 2009.
  1. smoothekang
    smoothekang New Member
    Just recently took off the cam gear to determine if there was a prob with the car. Did everything in the book to check to see if the timing was off or so. Now taking it apart the woodroff key was broke on the cam gear and shaft. Would this be considered a junk motor? Or can i still replace this and have a working engine. Any info would be appreciated. thx
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    well you more than likely bent valves but the bottom end is probably ok overall... it depends though, only one way to find out. take it apart
  3. MthaFuknGreen
    Lodi, CA
    take it apart and find out.
  4. newb
    newb phresh VIP
    Backwoods Northwest
    How far did the gear spin on the cam?
  5. Briansol
    yeah, if it was still 'locked in place' even with the key broken, it should be ok. if it was completely missing, that's a whole other ball game.
    if its a dual cam, you're a little safer... you only have one side to check most likely, and odds are the belt kept everything rotating properly from the good cam.
    if its a single cam, who knows what could ahve happened.
    pull some valves and find out.
  6. smoothekang
    The car was running at one point then cut off and had to be towed, The cam had a 45 degree broken off, the cam shaft was about the same i was just hoping that when it broke it didnt damage anything else.
  7. newb
    newb phresh VIP
    Backwoods Northwest
    I dont nderstand. What was the relationship between the cam and the gear? Did it look like the gear turned seperatly from the cam or did it look like it didnt move at all?
  8. serrilion
    serrilion In my own little world! VIP
    Vermont
    Hes making my head hurt:mad: lmao
  9. smoothekang
    well both cam and shaft looks as if both seem to broke at the same spot at the same time. iono not sure if that helped..
  10. 99sidude
    Ohio
  11. smoothekang
  12. smoothekang
    Anybody have a diy cam shaft replacement thread?
  13. 99sidude
    Ohio
    This Thread Is Worthless WithOut Pictures:ph34r:. A picture really does tell a thousand words. Especially in your case where it is tough to convey in words what the problem is.
  14. smoothekang
    I hope these pics help
  15. 99sidude
    Ohio
    Ahh the pics make it much easier to see what happened. You're going to need a new cam and camgear. Looks like the key sheared apart, and fucked everything. That sucks. You should be able to replace thoes pretty easily- stock d-series stuff is pretty inexpensive.
  16. newb
    newb phresh VIP
    Backwoods Northwest
    Looks like it spun quite a bit. Id take the head off and check everything out.
  17. efhondakid
    Akron-Canton, Ohio
    :werd: Im willing to bet it did some internal damage.
  18. austin20110
    austin20110 New Member
    Northern Va
    had to have, i've never seen one spin that much
  19. smoothekang
    of course this is not good but would it be wise for me just to change the cam and shaft? Or better yet just find another engine. I guess it wont hurt to try eh?
  20. newb
    newb phresh VIP
    Backwoods Northwest
    It would be wise to take the head off and inspect what you have.
