cam gear question??
Discussion in 'General Tech and Maintenance' started by FLounder, Jan 20, 2009.
  1. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    is it possible to change the cam gears without removing the cams? i have heard both ways..... thanks
    b series engines im talking about.
    1 person likes this.
  2. sleeper88
    sleeper88 My mom thinks i'm cool
    Parkesburg, pa
    It is possible, but getting them torqued back down to the right spec is hard. If you dont care about the right torque spec. Then take the old ones off ( make sure you don't loose the keys, there is one on each cam) and then put the new on and tighten the bolt down the best you can. Then retime it and put the timing belt on. When you tighten the timing belt back to the right tension. Then go back to the bolts holding cam gears on and get a wrench and tighten it to were you cant. Once you get to this point put the wrench back on the bolt to were you can hit it with a hammer or a small 5lb. sledge(best universal tool). Dont wack it just give it a good tap so it tightens it up good. While your doing this make sure it doesn't jump a tooth or anything. There you go
  3. FLounder
    or i could just use an impact wrench right? or is that too dangerous?
  4. sleeper88
    Parkesburg, pa
    To get the bolts off i would use it but for getting them back on i wouldn't just incase it jumps timing. I did this once and it worked fine
  5. FLounder
    its a done deal.... i got them torqued down by using a second ratchet on the crank pulley to stop the engine from turning over.
  6. eastbxc
    eastbxc Custom User Title
    Kansas
    wow that looks good man :D
  7. sleeper88
    Parkesburg, pa
  8. 94H_Ex
    94H_Ex Under employed
    Florida
    Nice cam gears guy
