Cam gears
efhondakid
My name is Byron.
I got a set of adjustable cam gears (from -20 to +20) and was wondering what i should degree them to, if at all. My set up now, stock cams and no head work, 11:1 pistons eagle rods and balanced crank, TB spacer, fuel rail, and adjustable FPR.
No need to degree at all, set them to 0. Honda did a pretty good job with that. Its another story when you decide to change your cams.
Shouldn't the camshaft manufacturer give you specs for degreeing their cams and you are supposed to use a micrometer to set that and do it off the dyno??
Sorry that's the only way I've ever heard of doing it.
Ok. Ya that's what I meant. I just wanted to know if I was being mislead.
