cam install questions/problems
Discussion in 'Engine Building' started by seanjuan, Aug 17, 2006.
  1. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    I began work yesterday changing out my stock b16a cams for a set of skunk2 stage1s
    I am not changing the timing belt at this time so I am attempting to just slip the belt off the old pulleys and onto the new adjustable pulleys
    the problem is that when I try to line everything up the cams don't sit right
    I have the crank pulley mark lined up with the mark on the belt cover and the allignment marks on the new gears are lined up but one of the vtec lobes is preventing the cam from setting correctly
    I'm not sure what the problem is but any tips would be appreciated
    I don't think it would be wise to just put the cam caps on and tighten them down like this... I'm affraid somethig would break
    thanks for the help
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Work your way from the front of the engine to the back. You want all the slack to be on the backside of the engine. Make sure the crank is at TDC, and then slip the belt over the exhaust pulley first, taking as much slack as possible on that side. Slowly inch the belt over the intake pulley. After you get the belt over both of the cam gears, rotate the crank counter clockwise a little bit: enough to take the rest of the slack out of the front of the belt. The tensioner bolt should be loose enough to allow the tensioner to take up the slack in the belt. Tighten the tensioner up after getting all the slack out, and rotate the crank a couple of revs to make sure the gear marks line up. They should line up just fine. I know how frustrating it can be to get the timing belt on if this is your first time. Hope this helps you out.
    Mike
  3. seanjuan
    Twin Cities, MN
    thanks
    I think that I didn't losen the tensioner bolt, so hopefully that is the problem
    I'm going to duck out of work early today and hopefully get that taken care of
    hopefully that is it because I still have to adjust valve clearance and reset the timing and get the cams broken in before an autoX this sunday
    do think it would be pretty safe to set the cams at +1 for the intake and -1 for the exhaust. or would it be better to just leave them both at 0 until i can get it tuned?
    thanks again, I'll let you know how it goes
    anyone else have any ideas or tips?
  4. MikeBergy
    Central Coast, CALI
    Safe, but I'd just leave them at zero until you get a chance to tune them.
  5. seanjuan
    Twin Cities, MN
    so I guess what I was worried about was that when the timing marks line up with cyl 1 at tdc there are valves open on cyl 2 which means that the lobes on that part of the cam are pushing down on those rockers
    this means that without the cam caps on the cams tilt toward the timing belt
    so all I have to do is put the caps on and the spraybars and start tightening the bolts down little by little until everything is sitting flush.... does this make sense?
  6. seanjuan
    Twin Cities, MN
    ok
    I tightened everything down and I think I'm good to go now
    I just have to adjust the valves and the distributor
    I got a start on the valves but have a question about that too
    the range for the intake is 15-19 so the natural assumption would be to set it to 17 but the feeler gauges I have doesn't have a 17 so I have to decide between 16 and 18 for the intake
    the exhaust I can hit the middle with a 19
    is it better to be on one side or the other of the middle when adjusting?
    also, if I'm going to change the degree of the the intake and exhaust cam I should do that before adjusting the clearances correct?
    thanks
  7. seanjuan
    Twin Cities, MN
    I don't have guages that add to 17
    but according to your "engine builder friend" I should set the intake to 18 and the exhaust to 20
    these settings would be one step looser than the middle of the range
    anyone else have an opinion on this?
    thanks blanco
  8. seanjuan
    Twin Cities, MN
    I was thinking about it more and it seems like if you made the gap smaller it would open the valve more... isn't that the point of larger cams?
    but at the same time I don't really know much about engines and bigger isn't always better
    thanks though
  9. seanjuan
    Twin Cities, MN
    never thought about it that way
    interesting
