My cam shafts on my b16 need replaced. if I was to replace them with b18c cams, would this be anything of a power gain, and would anything else need replaced?
yes gsr cams will be a power gain... not huge, but a little. you dont have to change anything else to use b18c1 (gsr) cams. however if you get type r (b18c5 or b16b) cams you should upgrade the valve springs as well.
