Cam Shafts And Cam Gears
Discussion in 'Engine Building' started by jdmcrx89, Jan 19, 2003.
  1. jdmcrx89
    jdmcrx89 Senior Member
    AL
    im lookin to get some cams and cam gears for my b16a, what are some good ones for me to get?
    alot of ppl said type r cam shafts
    best combo ive seen with proof is skunk 2 cams and cam gears.
    also when i order cams , what car do i order them for or any bseries part will fit into mine, like skunk2 cams for a type r or skunk2 for a gsr? is there a power difference? will they both fit?
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    all b series vtec cams are the same as far as fitting goes.... now what cams you get is all depending on what you want...
    are you going all motor? turbo? is this your daily driver? shit like that
    as all motor is concerned, personally as far as bang for the buck id suggest ctr intake cam and itr exhaust cam, still not exactly cheap....
    take it a step up and get skunk2 stage 2 cams, they recomend their valve train, and it's not a bad idea, not worth it to drop a vavle.... if your a baller and have alot of money to blow on toda shit, (over 5 bills for each cam) then the valvetrain, not to mention making sure your bottom end can handle the revving beyond redline it takes to get maximum potential out of those things ...
    now as far as turbo alot of people suggest GSR cams, skunk2 has a new turbo grind out but i havn't heard anything about it, and then there's always crower.
  3. jdmcrx89
    AL
    definately all motor
    i was lookin into skunk2 cam gears and shaft
    i wanna get the right parts the first time, im no baller, just a college student with a passion.
  4. jdmcrx89
    AL
    how does this setup sound?
    Car:
    89 Crx Si w/ B16a Sir1
    Mods:
    ITR Headers
    Skunk2 Racing Cams
    Skunk2 Adj. Cam Gears
    AEM CAI
    thats all about i wanna get for now, i wanna build my bottom end sometime around summer when i get more money.
  5. prawjEKt Cx
    upstate NY
    yeah that's a pretty normal set up.... just say header from now, it's singular, some people here will jump on you for that one
  6. Jeef
    Jeef NO MA'AM Moderator VIP
    Stay away from any cam gear with less than 5 bolts on it.
  7. B16
    B16 Super Moderator VIP
    yay area, CA
    dont forget your skunk2 springs and retainers :)
  8. jdmcrx89
    AL
    sorry ITR header lol
    well anyways my next question
    anyone used CTR Pistons and CTR Cam Shafts? are they good? or should i go with the Skunk2 setup?
    why i ask this is because with CTR Pistons and Cams i have more money to do pistons, cams, cam gears, with skunk2 i have only enough for cam shafts and adj cam gears.
  9. pissedoffsol
    not true. 3 slip, 4 don't.
    toda's own :)
  10. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Just picked these up... SPW Industries Adj. Cam Gears... be a real man and get 6-bolt cam gears :)
  11. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    When i find a honda for a decent price, i'm going to use Toda Spec C and Cam gears.. so IMO, Toda is one of the best.
  12. prawjEKt Cx
    upstate NY
    i ran ctr pistons and crane cams with a full crower valve train... i thought it ripped pretty damn hard.
  13. jdmcrx89
    AL
    how much is it for toda racing, pistons, cams, cam gears?
