we changed cams in my b16a swap now wont start? timming is perfect along with cam timing the spark seems really weak and when you crank it over the rev counter jumps up and down? ran before we did the cam swap?
sounds like dizzy problems... and do you know if the cams arent backward ex and intake switched? and mine did the rpm jump when my timming was really far off..what cams are you using need more info
you cant get cam the wrond way one has slots one doesnt? tryed a dizzy that i new worked from a mates car still no go ? xs power cams used them before without probs
