Cam/ tune ?'s
Discussion in 'Civic and del Sol - EG and EK' started by 408Projects, Dec 4, 2008.
  1. 408Projects
    408Projects JDM- Project Eg6
    California
    I got some more ?'s. OK i just put a b18c in my eg and it pulls hard. But its not the power im looking for so, i came across some stage1 cams and im going to install them but.... should i throw in some springs and retainers first? (i dont want a floter) then get a tune? i want max street power!!!! I have my chipped ecu redline @ 9200. I already taking out RSXtS by like 4 cars and super changed buicks. :feedback:
  2. zeppelin101
    zeppelin101 New Member
    Yes you should get the springs and retainers, get the whole lot then if you want to upgrade the cams in future you've already got the bases covered.
    Might want to look at something like skunk2 pro stage 1s if you want big n/a power, very good for street use apparently and exceptionally good cams.
  3. austin20110
    austin20110 New Member
    Northern Va
    are you sure they were racing you lol
  4. efhondakid
    Akron-Canton, Ohio
    Your car would run better with the stock map back in it. There is no need for a redline 1000rpms over what stock should be. Your motor stops making power at 8000rpms so there is no reason to rev it higher than that.
  5. 408Projects
    California
    Im not to sure because my car pulls all the way to 9200, And the cross over pops hard and loud @ 5700 then starts losing power around 9350-9500rpms. And yeah they were racing me i have it all on video. The car pulls hard. They thougt i was on the bottle. but nah. i heard the strings start to bend not until around 12:3 @ redline. So i was just wondering if i should upgrade the strings or not. its just a mid-cam. Only stage1. so i guess my ? is if i run that cam without upgrading you think it should be ok?
  6. 95b16coupe
    95b16coupe New Member
    ct
    just because your car keeps going faster, doesn't mean it's still making power at that high of rpm.
    your ass dyno is wrong.
  7. Matts96HB
    Matts96HB . Moderator VIP
    Dude, put that stock map back in your car ASAP or else your "hard pulling" b18c will be resting in pieces before you know it.
    Stock motor = Stock map.
    Properly built motor = Properly tuned map
    Poor GSR.
  8. efhondakid
    Akron-Canton, Ohio
    Naw d00d itz still makez powa, I dont need no redline, da 439586 redline is da best for ma stock motor.
    I dont know why people dont get it. :dunno:
  9. 95b16coupe
    ct
    people think it's like a checkbook. my account still has money, i still have checks.
    it keeps revving, must be going strong.
  10. newb
    newb phresh VIP
    Backwoods Northwest
    :confused:
  11. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The butt dyno is not caliberated.
  12. 95egswap
    95egswap Richie
    Kitsap, WA
    Im going to put my two cents in, the guy that owned my car before me put a D16ZC and chipped the ecu and the redline is 8200 but it only pulls to 7200 so there is no use in it going any higher than that! Just cos it goes higher doesnt mean its better!!!:eek:
