khai_tuan_nguyen
Hi guys.
I have a 97 hx coupe. I swapped in a b20 vtec. I just bought a fuel pressure regulator and a 255 lph fuel pump. I have je 12:1 pistons and the head has dual valve springs and they have been worked on for higher revs. I am goign to get obd2-1 and hondata s100. Then i am going to dyno tune. Since dyno tuning is expensive, what else do you guys recommend before i dyno tune it. I was looking at cams and cam gears? Any recommendations?
Once it is dynotuned i am done with the build.
Thanks
Khai
Thanks
Khai
