cams in 200whp ls/vtec
Discussion in 'Engine Building' started by S13 Slide, Oct 16, 2002.
  1. S13 Slide
    S13 Slide Junior Member
    alright, for those people who were able to get atleast 200whp in their ls/vtec set up. what cams did you use? btw right now i have the b16 pr3 pistons and im going to use a b16 head with stock headgasket. my goal would be 200whp. i know im going to need head work and some port matching but i'd just like to know which cams are up to the job. thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    is this monster going to be streetable?? if not.. skunk stage 3's , jun stage 3's...
    my friend has an ls/vtec that put down 180 with CTR cams... on stock LS internals too. he was a homo and didn't build it right.. he had somebody do it, and paid too much...
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    With B16 pistons and CTR cams with some gear tuning you should be close to 200. I assume you have an aftermarket header. If that setup doesn't get you there then add a Skunk2 IM that should do it.
  4. Havocprez
    Havocprez Member
    Phoenix, Arizona
    Why dont you just throw the crower stroker kit in it?
  5. S13 Slide
    yeah i'd like to have it somewhat streetable, im going with a 4-1 header w/ 2.5 collector and a skunk2 or itr manafold. so the ctr's would be able to do the job? i'd like to be over 200whp but id figure that would be a realistic goal. what about aftermarket cams? and i already have my ls block built. tried the all motor ls, with crower 404's. kinda ruff driving under 3k. thats why not the stroker kit. thanks
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    i say get the skunk2 stage 2's, from what i hear, they are the best for their money... remember to get their springs and retainers and sprockets too :)
  7. phunky.buddha
    Dallas / Fort Worth, TX
    I'm only making 185whp, but that's with an all stock B16 head on a B20 block. The head is basically choking the engine. My shop made 265whp on a B20/VTEC with Skunk2 Stage 2 cams, some crazy head work, and good tuning. I'm not tuned to 100%, so there's power left as is- but with any set of aftermarket cams I'd easily be well over 200whp.
  8. B16
    yay area, CA
    what on earth are you waiting for??? i'd take out a loan to finish that :D
  9. S13 Slide
    whats parts are you using in your block? what comp? thanks
  10. pissedoffsol
    click the link in his sig.....
  11. phunky.buddha
    Thanks Brian.
    There's actually a correction that I need to make on that page- I'm running 12.6:1 compression, not 12.5:1. I finally got the numbers I needed from Endyn and did the calculations myself... 12.6 is the actual compression.
  12. B16
    yay area, CA
    calesta, that is one mean motor man, i'm jealous ;)
  13. phunky.buddha
    You can have one too for not too much money. :D
  14. B16
    yay area, CA
    ya, already got the vtec shit, just need a bottom end, hmmm..... lol
  15. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Ill stick with boost! Less money and higher HP gains.
  16. phunky.buddha
    Actually more money, the way I want to do it.
  17. knowledge
    Beale AFB, CA
    Maybe. A home made turbo kit is extremly cheap! Like around $100.
  18. phunky.buddha
    True. You wouldn't want to turbo my engine without changing up quite a bit of stuff though.
  19. knowledge
    Beale AFB, CA
    True. If I was you calesta then I would stay N/A. But for a guy with a stock motor and nothing done to it yet I say it is cheaper to turbo it. Plus you would get quicker results from it that going N/A.
  20. phunky.buddha
    Yup. If I already had a D16 SOHC VTEC in there, I would have just dropped a turbo on it, and that probably would have been it. Since I had a POS D15B7 in there, it had to come out... and it's a little expensive to drop a B series in and turbo at the same time.
