cams?? need help
Discussion in 'HYBRID -> EG-EK / DC' started by marshall12395, Nov 26, 2012.
  1. marshall12395
    marshall12395 New Member
    im in abit of a pinch. so i wanna chance my cams in my b18c type r. im upgradeding my valve train, and on my car i have headers 421, 2 and half exhaust. so here my queston what kind of cams should i put most of my parts are skunk 2 so i wanna stay with them. what would be the best cams for my setup??
  2. Matts96HB
    Matts96HB . Moderator VIP
    It really depends on how much power you want out of the car. Set a power goal and take a peak at some all motor dyno sheets to figure out which combination of parts will net you the best results. These engines have been built thousands of times and the information is out there.
    For what it's worth, I have not heard good things about Skunk2 valvetrain.
  3. marshall12395
    i wanna get the max power for a daily driver. just not sure what size of cams my car can take
  4. Matts96HB
    If its a daily driver, I personally wouldn't want to mess with anything that required changing the stock springs and retainers. It just doesn't make me comfortable on something that I need to rely on. But to each his own.
    Skunk2 Pro2 and Pro3 seem to be the choice for most people with high hp all motor setups. I'd probably go with a set of those if you must.
  5. marshall12395
    you dont think it will be a reliable car by doing this
  6. Matts96HB
    It might be. It really depends on how well it is put together. I said that personally I would not put springs and retainers in something that I have to drive daily. I have experience with BC springs and retainers in my turbo'd LS and I was always fighting timing belt slack and tension.
  7. marshall12395
    ok but they say with bigger cams these should be upgraged. and i wouldnt really say its a daily drive its just a car i take at night to go cruising with buds lol. you know any other mods i can put for more hp???
  8. Matts96HB
    Considering it is a Type R engine, the cylinder head already flows pretty well. But, there's always room for improvement. If you are trying to get as much as possible out of the engine while staying all motor, its going to get expensive. You have a lot of options:
    Intake manifold
    Exhaust
    Intake
    Cams, valvetrain
    Larger diameter valves
    High compression pistons (though your engine already has a pretty high CR)
    Head work (porting, polishing, etc)
    Most importantly - a tune to go with all or virtually any combination of these parts
    Like I said before, simply throwing parts at it will not yield the best results. Research and a well planned build will net the best results, and end up being the least expensive route in the end.
  9. marshall12395
    ok thanks alot man.im starting to work on it next week.ill put put pics up when im done
  10. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    The farther you build the engine in any direction, the less reliable it will be. The harder you run the engine, the less reliable it will be.
    Any modification beyond stock, the tradeoff is always reliability - be it driveability, dependability or longevity (to include increased maintenance requirements). Also affected is fuel economy or lack thereof.
    There are 3 basic questions: 1) How fast do you want to go? 2) How much money are you willing to spend? 3) What are you willing to sacrifice in terms or reliability? (driveability, dependability, longevity & maintenance requirements)
  11. marshall12395
    lets just say it wont be a car il be traveling in and doing long trips. its a car i just wanna have fun with on the streets and track.money wise what ever it takes to do the mods i wanna do. you think it wont be a reliable car. and how much more maintenance will have to be done. i have heard of people doing this kinda work and beeting theres cars for 3-4 years and never having a problem
  12. Dual-500
    Fort Worth, Texas
    I have no way of ultimately knowing how reliable your build will be. Good luck with it. Relative to a stock build, it's lifecycle and maintenance will be a function of how hard you squeeze the lemon.
