Cams Question
Discussion in 'Engine Building' started by ericmugen, Jan 7, 2003.
  1. ericmugen
    ericmugen Junior Member
    Puerto Rico
    What cams are best=the Skunk 2 stage 3, Jun stage 3, Toda spec C, or Toda Erick Aguilar Spec.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    What kind of racing are you doing? The skunk2 Stage3 are horrible for a daily driver, they are not streeable what so ever. I am not to fimmiliar with toda's or JUN stuff so i cant tell you my oppion about them. Unless this is going in to a strickly race car (trailor queen) these aggressive cams are not good for you.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    for street. CTR cams are sweet. good gas mileage, and they pull harder than stock over 5K. i swear by mine for a daily driver
  4. asmallsol
    adam when did you get them installed? You put ctr springs and vavles in there too right?
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah whats your purpose for them, makes a huge difference... like pills said CTR is the way to go as far as daily driving good idling cams.
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    well, the most aggresive spec of any of those cams would be the eriks racing toda's, also known as spec D's... go check them out, they are insane... but, that would be for N/A drag application, probably not too streetable, and would need all sorts of other engine work done :).
  7. asmallsol
    The most aggressive (popular) cam really that can be used with normal street applications is the skunk2 stage 2, they give about 8-12 hp more then ITR's and still keep a reasonable idle
    (doing tags are alot easiyer on this board)
  8. ericmugen
    Puerto Rico
    I Know that the cams that i mentionate at the start are for drag race only but I want to know what are best.Thanks.
  9. B16
    yay area, CA
    well, be a little more specific with everything else you'll be running, like pistons, CR, P&P, intake mani, tb, fuel, engine management, balance blueprint, which B motor ?? these would help a lot
  10. 2 litre EG
    2 litre EG Senior Member
    so cali
    :withstupid: :werd:
    get more specific with your question please :D
    but personal recommendation as for trailor queen status is either toda spec D's or Crower Stage 3's...
  11. prawjEKt Cx
    upstate NY
    yeah im with him too.... don't forget the proper toda valves, springs, and retainers
    assuming this is a N/A drag setup
  12. brian11to1
    brian11to1 Senior Member
    What is the difference between Cams in an engine that has an automatic trans, and an engine with say a 5 Spd tranny'? And also for a daily driver waht is the best cam for a B18A1 (with new Sleeves, Rings, Pistons(10.5:1 compression] New rods "Crower", And new Main and rod bearings along with new thrush washers"Top-Line"). Thjis car is the car I use to get to and from school.. teh engine has a little over 180 Horse (187).
    Brian
  13. pills_PMD
    New Albany, OH
    i've had my CTR intake/ ITR exhaust cam in there for quite some time now.. the springs and retainers are sitting in my desk drawer still :( waiting for new valves and my head work over the winter
  14. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    As far as Hondas go, the cams in the auto's are less aggressive than the cams in the 5-speeds.
