Cams
Discussion in 'General Tech and Maintenance' started by DA69, May 16, 2003.
  1. DA69
    DA69 Senior Member
    psl Fl.
    does anyone have a link for a site with pics? im looking to find one that shows how to identify cams. b16,b18,typer and so on. thanx
  2. Kakarrott
    Kakarrott Member
    Im need the same thing only that i need to tell the GSR to b16A apart thanks aalllll
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    ctr have 2 rings by the distributor
  4. Gen2Teg
    Gen2Teg Senior Member
    san francisco
  5. DA69
    DA69 Senior Member
    psl Fl.
    well my cam has 2 rings on the protruding ring and 1 by the distributor. does anyone know what this on is
  6. pills_PMD
    New Albany, OH
    defintaly not a CTR then if it has only 1 on the dist. side...
  7. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    if it only has 1 ring it is an ITR cam.
  8. DA69
    DA69 Senior Member
    psl Fl.
    are you definitely sure of this? i just want to get what i paid for. they are supposed to be 2000 ITR cams. but i thank you for giving me this info. B)
  9. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    ok i looked at the site...very informative but the pics of the 92+b16 cams look exactly like the 94+gsr cams!! can anyone see a difference cuz i sure can't...and does anyone know the actual difference? i don't want any "i think" answers cuz that's just gonna confuse all of us lol...thanks
  10. kyleirwin
    kyleirwin Retired OG
    Vegas
    the 92+ b16 intake cam has an engraved ring on the dist. side of the protruding rings where the 94+ gsr intake cam does not.
  11. B16RacerN2NR
    Moving back West...
    oh sorry...i meant the difference between the 89-91 b16 cams from the 94+gsr cams...they look identical...anyone know?
  12. B16RacerN2NR
    Moving back West...
  13. pills_PMD
    New Albany, OH
    there is no way to tell unless you compare them to known ones.. the only very distinguishable ones are the ctr/ itr ones
  14. sbc
    sbc Junior Member
    if i remove the valve cover will i be able to see the rings you guys are talking about?? or do i have to remove the cams?
