Can car roll without shocks?
Discussion in 'General Tech and Maintenance' started by wikedeye, Jul 13, 2008.
  1. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I got this part car that I am stripping, but the junk man wont pick the shell up if it wont roll. My question is if I take the shocks and put the control arms back will the car still be able to roll? If not can I just shove a pipe or something in place of the shocks to give it some lift. I just need to be able to get the shell out of my garage when I am done.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yea it will roll
  3. wikedeye
    Savannah, Ga.
    Thats good to know. Thanx.
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Yar. It'll be bouncy as hell though, so if you are towing it or something, be ready for that.
  5. klyph
    klyph Dismember VIP
    North Pole, AK
    What kind of car? most hondas have the spring integrated into the strut, so there will be no strut whatsoever. It will roll that way only if the tires arent wedged into the wheel well. Also, if it has McPherson struts, then no, you can't remove the shock because it's integrated into the strut and acts as an upper control arm (kinda).
  6. AHHVTEC
    Alabama
    klyph is right keep in mind it will roll but not further than putting it up on a tow truck
  7. wikedeye
    Savannah, Ga.
    Its an ek coupe...there are seperate control arms. I only need to get it towed to a junk yard.
  8. BrokenRex
    BrokenRex New Member
    if you're getting it towed to a junk yard then yes. they can wench it up on a flatbed with out any wheels on the thing. and i'm sure you don't care if the tires are wedged up against the inner fenders if it's going there anyway. i've seen the local flatbeds wench up vehicles that were rolled and none of the four wheels rotate, or have any tires for that matter.
  9. brian11to1
    brian11to1 Senior Member
    This is seriously a thread? Wow. Reason #54527 I migrated away from HondaSwap.
    Poor HS got all the HT retards.
  10. wikedeye
    Savannah, Ga.
    Some of us are still new to building cars and have never had to deal with these situations. So if you dont have anything usefull to add then stay out of my thread.
  11. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    It shouldn't have to roll. I had three cars picked up and none of them rolled; they just dragged it on a flatbed.
  12. wikedeye
    Savannah, Ga.
    There is a junk man here in town that pays for scrap metal and things. He wont pick it up unless it rolls. I know I can get a wrecker to come and get it with his flat bed.
  13. sufikation
    sufikation Active Member
    Fruitland, ID
    no not the jumk yard!!!!
  14. wikedeye
    Savannah, Ga.
    Look at my build thread and you will see why its going to the yard.
