Can I format Fat32 with XP ???
randerson165
I have a mp3 player and i accidentally formatted it with xp not knowing what i was doing. I need to format the drive using fat32.
My question is, can I format my mp3 player with fat32 even though i'm running ntfs ???
yeah you can do it
the easiest way is to do it from a command prompt window
use the command: format /?
follow the instructions
Originally posted by La_Pieuvre+Jan 25 2004, 01:22 PM-->
randerson165
yeah you can do it
but if i'm running ntfs, when i do a command prompt, won't it format it as ntfs too ?
Originally posted by randerson165+Jan 25 2004, 06:43 PM-->
Originally posted by La_Pieuvre@Jan 25 2004, 01:22 PM
randerson165
yeah you can do it
not it you tell it which file system you want.
for example if your c: drive is NTFS and your mp3 player shows up as drive e:
open a command prompt (type "cmd" at the run)
and type this:
format e: /FS:NTFS
it'll only format the external drive e: as NTFS
Run:
format /?
from the command line and it should give you all the options.
Here, this is direct cut and paste from my command line window just now:
/FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS).
Your command line would be: format e: /FS:FAT32
Simple.
why would you want FAT32? NTFS is so much better, unless your MP3 Player doesnt work with NTFS. Follow what they say, open command prompt format c: /fs:fat32
or whatever drive letter its under.
