can i make 220+ whp w/stock bore b16a2?
Discussion in 'HYBRID -> EG-EK / DC' started by JDM_EK9R, Dec 14, 2006.
  1. JDM_EK9R
    JDM_EK9R all motor
    central, NJ
    Im thinking of building my b16a2. I was thinking of doing CTR stock bore pistons, and doing a more powerful cam like the ctr. how much whp can i extract from my b16? i dont wanna do ls/vtec due to the rod stroke. i wanna be able to spin the motor high without breaking. any ideas on other ppls setups?
  2. reikoshea
    Dallas, TX
    stock bore all motor b16...id say youd be topping out around 170-180 to the wheels.
    if you try to go further on stock bore stock stroke...you will need magic to go any higher.
    Some good cams (like skunk2 stage 3, pro 2, jun stage 3) PCT pistons, and a killer tune will probably get you close to that 160-170whp mark.
  3. JDM_EK9R
    JDM_EK9R all motor
    central, NJ
    ctr pistons, ctr cams tuned makes 200whp in b16a2. my friend made 180whp with itr cams and a pnp stock bottom end stock ecu w/vafc.
  4. reikoshea
    Dallas, TX
    all i can say is sure he did.
    i watched a guy make 202whp on the following build.
    stock bore
    ls crank
    cp 12.5:1 pistons
    stock port job
    skunk 2 springs and retainers
    skunk 2 stage 2 cams
    Blox Intake
    66mm TB, port matched
    tuned on neptune
    I seriously dont think your gonna come anywhere close to that on a stock bore and stroke.
  5. JDM_EK9R
    JDM_EK9R all motor
    central, NJ
    i guess ill be letting you know when i dyno tune after its done. it will be tuned on crome ems.
  6. BROKE DOWN
    BROKE DOWN New Member
    I have b-16 a2 and its about 30 whp and i thing it the biggest peaice of sh#$ thats on the road today
  7. greygoose
    greygoose Junior Member
    My question is are you trying to make 220whp on 93oct. all motor and daily driver the car?
  8. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Cams, pistons, gobs of head work (including performance valvetrain to match the cam), and awsome tuning will get you close to 200whp.
    Listen to what reikoshea is saying...
    dumb newb...
  9. get_nick
    Washington State
    BORAT!!!
  10. Andrew
    Tallahassee, FL
  11. get_nick
    Washington State
  12. civic93
    civic93 Junior Member
    a lot of tuning will get you close to 200
  13. werd2yourmother
    werd2yourmother JDM TYTE YO!
    Toronto, Canada
    Umm an LS crank wont fit into a b16
  14. divisii
    divisii Member
    why won't the crank work ... are you thinking deck height? Other than crank, the b16 & the b18 are the same.
    If your running on the street, the best way to achieve your hp...
    use a longer crank b18. You could use a shorter rod & move the oil ring up on the piston, to get a better r/s ratio. Regardless, a better-than-stock b18 bottom end rebuild can handle your revving.
  15. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ya the pont of a larger stroke crank is called stroking a motor.
  16. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    omniman pulled 200whp out of his b16. I don't recall what he was running, although I do know he was running Rocket Motorsports cams and valvetrain, along with some good port work. If you can rev the b16 high enough and have a high enough volumetric efficiency at those high revs, you can make power. The major bottleneck that needs to be tackled in just about every honda motor is the head.
    Port work, port work, port work. That's where the power will be made. Of course, you need the cams that will allow the engine to breathe, and the valvetrain that will keep up. The b16 is a good, easily revvable bottom end to work with. You can do it with lots of tuning on the dyno.
  17. werd2yourmother
    Toronto, Canada
    the ls has a deck height of 212mm while the b16 has a deck height of 203mm, so unless the pistons are considerably shortened, the piston will physically stick out 9mm. Thats why it wont work.
  18. hcivic.com
    are you fucking stupid the cranks have diffrent strokes and you use a shorter rod. it works just like in chevy land when you take a 350 and turn it into a 383 stroker longer crank shorter rods.
  19. werd2yourmother
    Toronto, Canada
    so that would mean that the rods would have to be ATLEAST 9mm shorter than the ls rods which are 137 mm. Unless he had custom rods made, there are no honda rods that short.
  20. GSRCRXsi
    MD
    just get cutom pistons with raised wrist pins. ive seen LS crank in a b16a with LS rods. how? custom pistons with raised wrist pins...
