Can i run different obd1 ecu's
Discussion in 'ECU's, Electronics, and Tuning' started by integraboomer, Jul 27, 2011.
  1. integraboomer
    integraboomer New Member
    I have a 95 gsr with a stock p72 i also have a p28.. could i run the gsr on the p28 just to see what it does? they are both obd1 ecus. Thanks
  2. Briansol
    Can you, yes
    Should you, no
    p28 is under fueled and does not contain iab or knock control.
    without a chip to basically make it a p72 spec, it will run your car like shit
  3. integraboomer
    Would it be fit to run an obd1 b16a. I am in the process of doing a swap as well
  4. eg6sir
    no.. ideal ecu would be the p72 because of the secondary butterflies..
  5. Briansol
    same thing... you want a p30 for a b16
  6. integraboomer
  7. tabKola
    tabKola New Member
    Tewksbury MA
    The GSR's intake manifold has 2 different paths that the incoming air can take, a long one and a short one. The butterflies are basically small throttle bodies in the manifold that change the path and they are controlled by the ECU.
  8. integraboomer
    so how would the p72 be ideal to run a b16? The p30 manifold does not have dual runners.
