Can I swap rear brakes off a 91 integra to put on
Discussion in 'Wheels / Suspension / Tires / Brakes' started by alex_b17a1, Apr 4, 2004.
  1. alex_b17a1
    alex_b17a1 Junior Member
    Can I swap rear brakes off a 91 integra to put on 95 civic hatch cx. If so what all do I need (please list in detail). thanks
  2. brian11to1
    brian11to1 Senior Member
    It wont work. You need them from either an EX Civic 92+, or 94+ Integra. and you need the complete rear trailing arm and ebrake cable. may also need the booster/master cylinder/prop valve
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You don't NEED the complete rear trailing arms, but it is a little easier.
  4. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Yes you can. I did it. It works just fine.
    Youll need to swap the trailing arms w/ brake stuff (obviously) and its best to swap the upper control arm too. That way you dont have to mess around with the bushings at all. You also need to swap the e-brake cable brakets from your civic to the teg cable.
    You dont need to change out the master or anything like that. It brakes just fine with little difference in pedal feel.
  5. brian11to1
    Im sorry. I didnt mean to mispost information.
  6. xj0hnx
    C.C.TX.
    It's not really misinformation, just not all fact :)
  7. brian11to1
    I said no, becuae I was under the impression you would need 94 or newer. So thanks for clearing it up. :p
  8. alex_b17a1
    so correct me if I am wrong I DONT need the ebrake cable or the trailing arm. what about a proportioning valve
  9. xj0hnx
    C.C.TX.
    You need an ebrake cable from rear disc and brakelines from rear disc.
  10. E_SolSi
