can i swap this in a civic?
Discussion in 'Members' Lounge' started by Briansol, May 22, 2009.
  1. Briansol
    Hai Guyz? I canz swaps this in mai civc?
    The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan 's Diesel United, Ltd built the first engines and is where some of these pictures were taken. It is available in 6 through 14 cylinder versions, all are inline engines. These engines were designed primarily for very large container ships. Ship owners like a single engine/single propeller design and the new generation of larger container ships needed a bigger engine to propel them. The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version. Some facts on the 14 cylinder version:
    Total engine weight:
    2300 tons (The crankshaft alone weighs 300 tons.)
    Length:
    89 feet
    Height:
    44 feet
    Maximum power:
    108,920 hp at 102 rpm
    Maximum torque:
    5,608,312 lb/ft at 102rpm
    Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
    For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
    Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
    this might be that same boat one that went around, only not installed in a ship yet
  2. phunky.buddha
    Dallas / Fort Worth, TX
    w00t
    You could have a 6 speed transmission hooked up to it- every single gear an overdrive.
  3. jamesA
    Wrong forum noob!
  4. awptickes
    MD
    You'll just have to do a little cutting to make it fit.
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    And there is a certain spot in the fender well you'll have to massage to make it clear the pulley.
    Think about this: IF honda had made that motor, It would have 2,799,333 HP. And it would have been NA. (Assuming the same efficiency of an ITR motor)
    That has to be the least efficient motor I've ever read the numbers on. 25,480 liters and 7,780hp? Thats 3.3 liters of displacement per 1 horse power. Certainly they could have done better than that. I know they can't match an ITR motor with that kind of size, but those numbers are still retarded.
    And the starter / flywheel is hilarious. The engineer photocopied a car motor and blew it up 90879%
  6. awptickes
    MD
    102 RPM redline......
    Also, it's diesel.
  7. awptickes
    MD
    220.106436 ft/lb of torque per liter. That's nothing to laugh at.
  8. Drake
    Drake Well-Known Member VIP
    Use the search function, this has been covered eleventy billion times^2.
    On a more serious note, that is one big ass motor. The amount of torque that thing generates is insane. I wonder if you could swap that into one of those strip mining deals, you know the one that takes 17 people to drive.
  9. chestercheeto48
    chestercheeto48 Senior Member VIP
    madison, WI
  10. DarkHand
    DarkHand Senior Member VIP
    Chicago, IL
  11. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    I'd hate to change the head gasket in that once it's installed......
  12. phyregod
    phyregod !!YTINASNI
    Central Texas
    Wonder how many qts of oil are involved in an oil change?
  13. E_SolSi
    you'll never get through emissions with a 2 stroke diesel...
    do you plan on driving this on the streets? or will this be a strictly track toy??
  14. Drake
    Oil? They use the souls of young Croatin children to lubric their machine of death.
  15. BodyDroppedNikes
    caught in a mosh...
    id hate to be the poor bastard to adjust the timing on that thing
  16. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Shouldn't be a problem with the swap.....it's plug and play lmao
    Might need to modify a few things (not sure if your stock alternator will mount correctly)
  17. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
    I wanna see the motor mounts for that thing..
  18. 95b16coupe
    95b16coupe New Member
    ct
  19. nootrac22
    exeter pa
    now I know what the Somali pirates are after, the meanest civic ever.
  20. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    As long as you can keep the AC, there's an almost endless supply of displaced orphans in the Balkans.
