Can I Use 94 Gsr Engine Harness And Int Harness To
Discussion in 'ECU's, Electronics, and Tuning' started by pootSIracer, Mar 4, 2003.
  1. pootSIracer
    pootSIracer Member
    Scotia,NY
    hey I was wondering if a 94 gsr harness can be used on b16a to covert it over to obd1 from two I also have 94gsr ecu &distributor iam puting the motor in my 1993 civic dx
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    What do you need the GSR interior harness for?
    And why in the world would you want to convert from OBD1 to OBD2?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  4. AllMotorMonster
    Inland Empire foo!
    Oops...
    Well punctuation and proper grammer are your friend. Had it been written properly, I would not have asked.
    Now I'm really confused because I could have sworn there was something about changing the interior harness.
  5. pissedoffsol
    you want to convert your obd1 car to obd2?
    the real question is why.
    If your car is obd2, get a conversion harness for the ECU from kenji, to conveert the ecu mount wires to obd1, plug in the gsr ecu thats obd1, and wire the car up with obd 1 electronics, using the gsr engine harness.
    interior harness doesn't come into play at all.
