can i use itr intake cam with b16 exaust cam?
JDM_EK9R
all motor
im wondering how well my motor would run with itr intake cam, and b16a2 exaust cam? motor = b16a2 running on an obd1 p72 gs-r ecu.
i tried a similar combo and found after 2 dyno pulls that my ctr cams gave a better torque curve and overall 23 higher horse on a pnp head,b16a2
it should work but i would go with the ctr cams
So You say that CTR camshafts(from K20) is better than ITR camshafts for b16 head???
The spec are similar
k series cams will not fit in a b series head. Hence the point of engine series.
