Can I Use My 92 Si Ecu
first of all.. i did not say a gsr harness...i said a gsr ecu...and i have done the same swap wth my 92 si...and yes chipping the ecu would be cheaper
Originally posted by civic_SI_hatch@Mar 12 2003, 02:59 AM
ive done the same swap... you can use your old harness from the 92 si which will be easier... distributor, and injectors... just chipp the ecu or get a 94 95 gsr or a p30 ecu and your ready... you'll probably need a gsr mount also
Ok, fine.
But you did say to use the 92 SI harness, and this is not correct either.
its not correct either? how would you know? you cant even read B)
can i use a 99-00 si engine harness? if i had th change the wire harness.
most likely i will get the ecu chipped but i have a question about that too.
if i get mu ecu [p28]chipped to the b16a2 specs then to i need to add a wire for the knock sensor?
can i still use one o2 sensor ? and what to i due with the second one?
what about the crank position sensor?
Good way to make friends and get yourself flamed.
How would YOU know, you're just a interent know-it all.
I however, have ACTUALLY DONE this swap more than once.
No, the 99-00 Si harness will not work in a 92-95 car. They are different.
No, the chip I have that is stock B16A has the knock sensor removed so you don't get a MIL code.
Yes, you use just 1 o2 sensor.
Leave it in, or plug it off, doesn't matter.
No need for the CPK, just leave it unplugged.
thank you for all this info about this subject. this will help greatly help with my swap
props to 'AllMotorMoster', 'pills_pmd' and civic_SI_hatch and all others for the info. :worthy:
get myself flamed? :) i like to see that happening... but i bet your just a interent know-it all trash talker...
your a dumb ass thinking your the only one who does the swap more then once... :D and i however done the swap more then once... and i own a 92 si with a b16a2... :lol:
